05 November 2026, 06:00:07
ЛИДЕР-С
13 March 2018, 06:55:00
13 March 2018, 06:57:15
silandser, changed object type from   to  Static speed camera Static speed camera.
silandser, changed speed limit from 30 to 60.
silandser, changed object notification distance from 500 to 340.
silandser, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'MultaRadar SD580'.
silandser, confirmed object added via Mapcam.info program
13 March 2018, 06:57:23
13 March 2018, 14:07:17
IDX: 665915 похоже перенесли с ул. Обручева.
13 March 2018, 14:08:20
При случае, проверю
29 June 2018, 12:47:41
29 January 2019, 16:48:43
мото -1 -1
18 April 2019, 13:49:27
silandser, switched object to test mode
02 July 2019, 13:05:30
silandser, changed object description from 'MultaRadar SD580' to 'КОРДОН-М 4'.
silandser, turned off test mode
03 July 2019, 13:19:04
31 July 2019, 08:02:01
Вчера утром был. А уже вчера вечером не было (см.фото в соседней точке). Сняли. Перевел в тест.
31 July 2019, 08:02:09
07 October 2019, 16:06:22
LordGrey, changed camera model.
07 October 2019, 16:10:53
silandser, changed object description from 'КОРДОН-М 4' to 'MultaRadar SD580'.
30 December 2019, 12:14:37
07 January 2021, 21:48:36
Нет давно "мульта" висит Кордон
18 January 2021, 17:51:10
silandser, changed object description from 'MultaRadar SD580' to 'ЛИДЕР-С'.
18 January 2021, 18:02:59
Молодец!
20 January 2021, 18:22:13
08 February 2021, 18:16:53
19 July 2024, 14:48:19
19 July 2024, 14:51:14
