05 November 2026, 04:26:26
ЛИДЕР-С в спину
13 March 2018, 06:51:55
13 March 2018, 06:54:00
silandser, changed object type from   to   .
silandser, changed speed limit from 40 to 60.
silandser, changed warning direction from 62 to 61.
silandser, changed object notification distance from 500 to 300.
silandser, changed object description from 'Объект добавлен с помощью программы MapcamDroid (offline)' to 'MultaRadar SD580 в спину'.
silandser, confirmed object added via Mapcam.info program
13 March 2018, 06:54:08
18 April 2019, 13:48:46
18 April 2019, 13:48:58
silandser, switched object to test mode
02 July 2019, 13:04:07
silandser, changed object description from 'MultaRadar SD580 в спину' to 'КОРДОН-М 4 в спину'.
silandser, turned off test mode
03 July 2019, 13:13:42
31 July 2019, 08:00:54
31 July 2019, 08:01:24
Сняли. Перевел в тест.
31 July 2019, 09:15:56
Спасибо за фотоотчет. Берегите глаза)
31 July 2019, 08:01:04
07 October 2019, 14:57:49
Камеру вернули
07 October 2019, 16:00:42
Не муляж?
07 October 2019, 16:05:28
07 October 2019, 16:05:37
Вернули MultaRadar SD580
07 October 2019, 16:05:55
LordGrey, changed camera model.
07 October 2019, 16:09:38
07 October 2019, 16:10:26
silandser, changed object description from 'КОРДОН-М 4 в спину' to 'MultaRadar SD580 в спину'.
18 January 2021, 17:51:24
silandser, changed object description from 'MultaRadar SD580 в спину' to 'ЛИДЕР-С в спину'.
08 February 2021, 18:22:43
15 May 2021, 09:32:01
15 May 2021, 09:32:49
Камеру сняли. Крепеж весь на месте. Скорее всего, камера вернется
17 May 2021, 21:04:47
17 May 2021, 21:05:11
Камеру вернули
18 May 2023, 14:13:33
