05 November 2026, 05:53:41
Азимут 4 [41км 200м]
23 June 2019, 13:56:15
23 June 2019, 13:56:50
В тесте, проверю
23 June 2019, 13:57:06
serezhka, switched object to test mode
23 June 2019, 18:46:25
23 June 2019, 18:46:31
23 June 2019, 18:46:42
23 June 2019, 18:48:36
А почему в тесте? Камера стоит, ящики с оборудованием висят; если еще и не работает - скоро начнет.
23 June 2019, 19:52:19
Не уверен был.
23 June 2019, 19:46:04
abbc, changed object description from '???' to 'СКАТ-С'.
23 June 2019, 19:46:57
для мото 0 -1
23 June 2019, 19:50:49
serezhka, turned off test mode
23 June 2019, 20:05:42
serezhka, changed object latitude from 37.604817 to 37.604804
serezhka, changed object longitude from 55.392761 to 55.392260
23 June 2019, 20:26:45
serezhka, changed object latitude from 37.604804 to 37.604726
serezhka, changed object longitude from 55.392260 to 55.392343
serezhka, changed object view angle from 15 to 20.
23 June 2019, 21:51:00
serezhka, changed object latitude from 37.604726 to 37.604756
serezhka, changed object longitude from 55.392344 to 55.393368
23 June 2019, 21:51:32
Установил по столбам
01 August 2019, 06:14:02
vaz2015, changed speed limit from 70 to 90.
vaz2015, changed object description from 'СКАТ-С' to 'СКАТ-С [41км+200м]'.
01 August 2019, 06:15:43
Скорость установил согласно штрафа с  соседней камеры    https://mapcam.info/speedcam/point.php?idm=Jgb0wKeHuDm
14 August 2019, 06:39:00
14 August 2019, 06:39:50
Авто двигается из Москвы - подпись неверна.
14 August 2019, 06:39:18
14 August 2019, 06:39:20
15 August 2019, 15:45:09
Zenduri, changed object description from 'СКАТ-С [41км+200м]' to 'СКАТ-С [41км 200м]'.
03 September 2019, 12:19:12
16 September 2019, 11:58:51
25 September 2019, 12:19:41
Verr, changed speed limit from 90 to 110.
30 September 2019, 18:39:09
04 April 2020, 13:53:32
Парная камера, на среднюю скорость.
04 April 2020, 14:09:18
Сейчас сделаю
01 October 2021, 22:05:37
01 November 2021, 21:28:05
silandser, changed warning direction from 0 to 1.
silandser, changed object notification distance from 500 to 900.
07 April 2022, 05:53:11
14 March 2023, 23:03:09
007MCD, changed object description from 'СКАТ-С [41км 200м]' to 'Азимут 4 + СКАТ-С [41км 200м]'.
007MCD, changed camera model.
05 June 2023, 10:05:54
007MCD, changed object description from 'Азимут 4 + СКАТ-С [41км 200м]' to 'Азимут 4 [41км 200м]'.
24 August 2024, 07:45:05
26 August 2024, 13:22:47
05 September 2025, 08:48:05
